First time here? Check out the FAQ!
asked 2012-05-06 12:01:09 +0200
Anonymous
Installation from rpm fails on Fedora.
Try to use option --nogpgcheck. So your line will be like that:
yum install *.rpm --nogpgcheck
But are you sure about the use of *.rpm?
Good luck!
LibreOffice is made available by volunteers around the globe, backed by a charitable Foundation. Please support our efforts: Your donation helps us to deliver a better product!
Asked: 2012-05-06 12:01:09 +0200
Seen: 323 times
Last updated: May 11 '12
Del Operator in Libreoffice Math
Re-creating windows search filters
Can't load IA 32-bit .dll on a AMD 64-bit platform
Disable Automatic Updates in Debian globally for all users? [closed]
How to set system wide options / settings / prefrences [closed]
Pics disappear from my text document
Content on this site is licensed under a Creative Commons Attribution Share Alike 3.0 license.
