Error 1714 Problem Need 3.3.0 RC1
asked 2012-09-12 00:26:34 +0200
Lern2Swim gravatar image Lern2Swim
1
I'm on 64 bit Vista.
I am trying to install LO 3.6.1 and am getting an error 1714. I've found the existing solution (to reinstall the previous version and uninstall it correctly) and am trying to attempt it. However, it appears the version I had previously is not available to download anywhere. The error message is telling me that I need "LibreOffice 3.3 (4cf8f8a3)." With a bit of research, it appears that this was version 3.3.0 RC1.
As far as I can tell I can't do anything about this error without that. I've tried both CCleaner and Revo Uninstaller. Revo (which is what I used to uninstall the old LO version in the first place) sees nothing related to LO. CCleaner shows the LO msi installer (as does windows) but seems incapable of doing anything with it. There is nothing related to LO showing in the uninstall key in the registry.
I'd appreciate any help I can get. Thank you.
delete close flag offensive retag edit
I already removed that folder. Does anyone else have any ideas? Or somewhere I can get that release?
Lern2Swim ( 2012-09-14 21:00:49 +0200 )edit
I keep getting emails telling me to accept the best answer here. The only answer posted doesn't solve my issue. Any other ideas?
Lern2Swim ( 2012-09-26 10:23:02 +0200 )edit
answered 2013-01-31 03:55:42 +0200
qubit gravatar image qubit flag of United States
5693 3 48 41
Hi @Lern2Swim,
(Just to add in a link regarding what you said in your question) per this answer about Error 1714, it appears that if you can't find the installation tools for your particular build, you may instead remove all files/registry information manually: http://ask.libreoffice.org/en/question/5189/help-install-error-1714-on-vista/
Are you still having an issue trying to uninstall 3.3.0? We might be able to dig up an install manifest, which you could use as a kind of "hit list" for clearing out your filesystem, registry, etc..
link delete flag offensive edit
answered 2012-09-12 03:26:11 +0200
mariosv gravatar image mariosv flag of Spain
4659 20 46
Try resetting the user profile: http://wiki.documentfoundation.org/UserProfile
Login/Signup to Answer
Donate
LibreOffice is made available by volunteers around the globe, backed by a charitable Foundation. Please support our efforts: Your donation helps us to deliver a better product!
Question tools
Follow
1 follower
subscribe to rss feed
Asked: 2012-09-12 00:26:34 +0200
Seen: 117 times
Last updated: Jan 31
