Problem formatting Header
asked 2012-09-17 10:16:12 +0200
alobo gravatar image alobo
47 1 6
updated 2012-09-18 07:50:37 +0200
I cannot get rid of these 2 horizontal lines of the header, please see here: http://dl.dropbox.com/u/3180464/header.jpeg
I've tried Format Header/More and selected Set No Borders, but the 2 lines are still there!
Thanks
PS:You can find a test document with 2 pages here: http://dl.dropbox.com/u/3180464/test_header.odt. Thanks
delete close flag offensive retag edit
2
answered 2012-09-17 11:17:04 +0200
manj_k gravatar image manj_k
5947 4 35 53
updated 2012-09-18 10:28:16 +0200
You can remove the borders via
F11 → Page Styles → First Page → Modify... → Header → More... → Borders
or
click on "Border and Background..." Border and Background
EDIT 2012-09-18
(Due to
http://dl.dropbox.com/u/3180464/header2.jpeg
http://dl.dropbox.com/u/3180464/test_header.odt)
How to remove the borders in the header(s) of the document:
(1) First Page
Styles and Formatting (F11) → Paragraph Styles →
Heading 1 → Header → (right click) Modify → Borders
firstpage_borders
(2) Page 2
That's apparently direct formatting:
Select the header → Menu Format → Paragraph → Borders
page2_borders
link delete flag offensive edit
Yes, this is what I'm doing, but the lines remain there: http://dl.dropbox.com/u/3180464/header2.jpeg
alobo ( 2012-09-18 07:39:47 +0200 )edit
@alobo: I have added EDIT 2012-09-18
manj_k ( 2012-09-18 10:30:59 +0200 )edit
Thanks, it worked! But I think there is a little mistake in (1) First Page Styles and Formatting (F11) → Paragraph Styles → Heading 1 → Header → (right click) Modify → Borders It should be: (1) First Page Styles and Formatting (F11) → Paragraph Styles →Header → (right click) Am I wrong?
alobo ( 2012-09-21 09:21:21 +0200 )edit
(I do not know how to insert a new line in these comments. If I click Return the comment gets automatically posted)
alobo ( 2012-09-21 09:28:56 +0200 )edit
@alobo: "a little mistake" — in "Hierarchical" view it is "Paragraph Styles → Heading 1 → Header", in "All Styles" view it is "Paragraph Styles → Header". ;)
manj_k ( 2012-09-21 20:40:47 +0200 )edit
@alobo: "how to insert a new line in these comments" — I don't know the answer to this problem; that's apparently not possible.
Update: 2 x Shift+Enter
manj_k ( 2012-09-21 20:49:32 +0200 )edit
answered 2012-09-18 19:58:38 +0200
bllgvn gravatar image bllgvn flag of Canada
141 4
http://bllgvn.wordpress.c...
This may not be the answer that you're looking for but I copy and pasted the content of the original document into a new document and the issue didn't transfer over plus I was able to keep all of the formatting with one exception I lost the footers as well as the headers
answered 2012-09-17 10:33:58 +0200
Bart_ gravatar image Bart_ flag of Netherlands
113 11
http://pleh.info/
Have you tried deleting the header by clicking the blue box "Header (first page)"?
That should just remove everything and let your start from scratch when you recreate the header.
In effect, I delete the header, but the 2 lines come back as soon as I try to add contents to the header,even if I set the style to no border: http://dl.dropbox.com/u/3180464/header4.jpeg
alobo ( 2012-09-18 07:40:49 +0200 )edit
alobo ( 2012-09-18 07:40:50 +0200 )edit
alobo ( 2012-09-18 07:49:39 +0200 )edit
Login/Signup to Answer
Donate
LibreOffice is made available by volunteers around the globe, backed by a charitable Foundation. Please support our efforts: Your donation helps us to deliver a better product!
Question tools
Follow
1 follower
subscribe to rss feed
Asked: 2012-09-17 10:16:12 +0200
Seen: 363 times
Last updated: Sep 18 '12
