1
Problem in Bullet and Numbering
asked 2012-10-18 23:55:50 +0200
moji_helooo gravatar image moji_helooo
11 2
updated 2013-03-26 19:44:04 +0200
manj_k gravatar image manj_k
5721 4 33 48
My language is Persian and i'm writing right to left.I go to Bullet and Numbering and choose the Numbering type the i change "After )" to "Befor )" as something in Persian then it works correctly (In MS Power point doesn't work correctly). But when i save file and after than open that file, that my Numbering changed to Bullet. what should i do to fixing this problem?
thanks
delete close flag offensive retag edit
What type file do you use to save?
mariosv ( 2012-10-19 00:18:54 +0200 )edit
.odp .The default type. i work in Fedora 17.
moji_helooo ( 2012-10-19 02:49:46 +0200 )edit
I saw the reported bug. my problem and that bug are the same. But i didn't understand how do i fix this problem?
moji_helooo ( 2012-10-19 18:05:19 +0200 )edit
1
@moji_helooo – The bugfix will be available in LibreOffice 4.0.3.
manj_k ( 2013-03-26 19:47:33 +0200 )edit
1 Answer
1
answered 2012-10-19 14:06:22 +0200
5721 4 33 48
updated 2013-03-26 19:43:01 +0200
That looks like → Bug 42569 - FORMATTING: Bulleted list numbering lost on saving RTL presentations
(Please have a look at the attachements, too).
Bug 42596 has been marked as a duplicate of
Bug 37692 - RTL list numbering reverses its direction.
EDIT 2013-03-26
Bug 37692 has been marked as a duplicate of
Bug 38951 - RTL numbering with wrong direction in Textbox
Status: RESOLVED FIXED · target:4.0.3
link delete flag offensive edit
Current status of fdo#37692 is NEW.
qubit ( 2013-02-01 04:12:02 +0200 )edit
Login/Signup to Answer
Donate
LibreOffice is made available by volunteers around the globe, backed by a charitable Foundation. Please support our efforts: Your donation helps us to deliver a better product!
Question tools
Follow
subscribe to rss feed
Asked: 2012-10-18 23:55:50 +0200
Seen: 185 times
Last updated: Mar 26
