Installation on Linpus problem
Hello everyone.
I am a complete linux newbie, and I got Linpus installed on my laptop when I bought it. I’m not even sure about the version.
I am having problem with the installation. Following the instructions given in the readme file, when I unpack the downloaded file, I go to RPMS directory, open it in terminal. Use su command to sign in as administrator. Then I use the command yum install *.rpm. I get prompted to download 390MB, I say yes.
Then a lot of dialogues appear and at the bottom I get NotImplementedError and the command stops. I have no idea what it means and nor I know how to proceed and how to install it. Obviously no files have been downloaded.
Does anyone have any solution to this problem? Thank you
Hi @Anonymous2,
I don’t know much about Linpus beyond the fact that it’s derived from Fedora.
When you say “Following the instructions given in the readme file…” – is that a README file included in Linpus packages, or is that something that you’ve downloaded directly from the LibreOffice website?
Is there a Linpus-specific support forum? I wonder if someone there might have direct experience installing LibreOffice on this distro.
