Regex issue: "replace with" box unintentionally interpreting Regex characters literally
I’m still fairly new to Regex so am trying to work out where I’ve gone wrong here…
I am trying to replace just the number ‘2’ with the number ‘5’ in the following example, however all the Regex characters used to locate the 2 in question are being erroneously added in the “replace with” box… where am I going wrong?
The first of the two Screenshots supplied shows what I’m trying to achieve and the second the incorrect result achieved.
Cheers.
(image inline display enabled by ajlittoz – newcomers, please, use the correct tool to add screenshots: this is the “slide” icon, not the “paperclip” which is a generic upload tool; the “slide” is specially intended for pictures)
Text is better than photos.
You search for \),.,2 and quoted the ) but not the . wich is also a special character
Try ( \),.,)2 and replace with $1 5 to keep the found part before the 2 and change only 2 > 5
To fully answer OP’s question, regexp are considered only in the Find argument. The Replace argument is interpreted literally, except for some escape sequences starting with \. As \) is not a registered escape sequence, both characters will be inserted as members of the Replace.
Similarly, the dot . in Replace is just a dot.
You can copy effective parts of the matching Find provided these parts are identified as parenthesized groups. They are designated as $n where n is an integer corresponding to the rank of the group left parenthesis (this is important when groups are nested).
For details, see built-in help.
