LibreOffice recovery does not work and causes data loss
I use LibreOffice Writer version 5.0.0.5 (x64).
I save all documents frequently and almost never have a document open that is not saved.
When LibreOffice is restarted after a crash, it always shows recovered documents for documents that had been saved and therefore did not need to be recovered.
I once tried opening the recovered document and it turned out to be an earlier version. So what it comes down to is that if you use LibreOffice recovery, you will lose data.
Can you please fix this?
