How to add a cross-reference without separator?
Hi.
I’m trying to reference an image legend in my document. I created the legend using a paragraph style which is numbered with a separator. For example, picture number 1’s legend will show as Figura 1. Description (Figura + space being the separator). I want to reference only the number in the text, but couldn’t find a way to do this. I select Insert → Cross-reference → Numbered paragraphs → Number (or Number with context, or Number without context) and it always comes with the separator.
Any ideas?
Thanks
No way to do that with numbering. You better create a new number range, and use its field in normal text (without numbering) like “Figura . Description”
