Is it possible to index invisible entries?
You can create an invisible entry by:
Insert -> Table of contents and Index -> Index Entry
Now, in the Index drop-down, define a new name like "Invisible". If you change the text in the "Entry" field, the index entry will be created but the text will not be visible.
Ok, what about creating a table of invisible entries? For some reason I was not able to create such a table. Even selecting the user defined "Invisible" index name.
Works for me with 6.0.0.3 (x64). You might want to provide a sample file (by using an external share, and posting a link to your edited question).
Hi, somehow, after a rebooting it worked! Should I delete the question?
