Help with a formula
Look at the picture. How to do, so where a number in green cell belongs to one of the ranges specified by columns A and B, the corresponding value from the column C is displayed in blue cell. As in provided in three examples.
image description
Sry for my English!
(edit: activated screenshot -AK)
Look at the VLOOKUP. You actually don’t need two columns for limits; a single column already defines your limits (what’s less than next position belongs to previous range).
Thank you :wink:
Hi @kyojin, From what I understand, A is the minimum and B is the maximum, and the range is continuous (1 to 10, 11 to 20, 21 to 30 and 31 to 40). Then you can directly use the = VLOOKUP(B17;B$11:D$14;3;1). Note that the last option is 1, if zero is the error. . Formula according to image.
image description
If the answer met your need, please click on the ball Descrição da imagem to the left of the answer, to finish the question.
Thank you, that helped :wink:
