Libreoffice 6 calc: speed up vlookup, match, index search
Hi,
I have installed libreoffice 6.0.1.1 under ubuntu mate 16.04 64 bit. I have a calc file with 35 sheets. In particular, one sheet is made of about 500 rows and about 50 columns.
The sheet has 2 columns with match and index and 1 column with vlookup while the other are simple formulas as countif, count and four operations.
When I add a new row or when I change one value in a cell that requires to update the entire row, the update is extremely slow about 60 seconds. The same when I save the file.
My formulas are:
Nested match, index
=MATCH(1,INDEX(($S$18:$S$463=LARGE($S$18:$S$463,ROWS(B$17:B445)))*(COUNTIF(B$17:B445,$A$18:$A$463)=0),),0)
Nested index, match, index
=INDEX($A$18:$A$463,MATCH(1,INDEX(($AS$18:$AS$463=LARGE($AS$18:$AS$463,ROWS(AW$17:AW445)))*(COUNTIF(AW$17:AW445,$A$18:$A$463)=0),),0))
Standard vlookup
=VLOOKUP(AW446,$A$18:$AS$463,45,0)
I disabled openGL, experimental features and search criteria via:
Menu/Tools/Options/LibreOffice
calc/Calculate - Searc criteria = and
<> must apply to whole cells.
Unfortunately, I cannot speed the process. I tried also to copy this sheet into a new empty file, but the result is more or less the same. I cannot use openCL since it is not supported by GPU and enabling or disabling it does not make any effect.
What can I do in order to make usable the sheet?
Thank you
I have i7-3537U CPU with 8 GB DDR3 1600 MHz RAM and EVO 850 SSD.
I followed this guide and now the OS recognizes my openCL v1.2 compatible CPU Intel(R) HD Graphics IvyBridge M GT2.
However, libreoffice disable each time openCL from the options.
