Opening .xls files problem [closed]
asked 2018-02-26 12:21:34 +0200
Motim gravatar image
updated 2020-11-03 22:16:17 +0200
Alex Kemp gravatar image
Hello, I have downloaded some excell pages with .xls suffix, when I double-click on them or right-click open with "calc" it opens the writer and all info on the page does not look like a normal spreadsheet. Is there some way to make it normal ? Answers will be appreciated Thanks Motim
close date 2021-04-20 03:47:22.505724
Share the file.
gabix gravatar imagegabix ( 2018-02-26 12:58:10 +0200 )edit
An alternative method is to start the Calc program first, click on File => Open, then navigate to the xls file you want to open, highlight it and click Open. But if your first two methods didn't work, I doubt this one would succeed either. As gabix suggests, share the file.
ve3oat gravatar imageve3oat ( 2018-02-27 01:54:54 +0200 )edit
So what does it look like?
erAck gravatar imageerAck ( 2018-02-27 16:37:45 +0200 )edit
