Put a bibliographic input as a cross reference and keep it saved in the document
asked 2018-04-18 21:05:16 +0200
this post is marked as community wiki
This post is a wiki. Anyone with karma >75 is welcome to improve it.
Hello all, how are you?, I'm just joining to the LibreOffice forum. I'm doing a thesis and I need to insert a bibliography but I need every input numbered and formated like this:
[1] Vinton G. Cerf (1997). Breve historia de la Internet [Artículo en línea]. Internet Society. Disponible: https://www.internetsociety.org/es/br.... [Consulta: 2017, Septiembre 9].
and I need the number [1] as a cross reference to insert in the body of the thesis, how can I do that?, because right now I'm doing it manually (not by inserting a bibliographic index). I mean, writing thre bibliographic by the "old method" and establishing the cross reference manually too through the cross reference menu.
...Almost forgot, once I've inserted the cross reference (after created) and moved the file to another computer with LibreOffice installed, the reference exists in the bodyof the document and if I click it it sends me to the origin of the reference but the reference doesn't exists in the field of establish reference (cross reference menu).
Thanks in advance for the help.
@vram: Welcome to the forum! In the future, please do not post as community wiki. For more information, see guidelines for asking.
Jim K gravatar imageJim K ( 2018-04-19 17:13:42 +0200 )edit
Thank you for the clarification and I'm sorry for the mistake
vram gravatar imagevram ( 2018-04-20 21:41:26 +0200 )edit
1 Answer
answered 2018-04-19 17:17:58 +0200
updated 2018-04-19 17:26:06 +0200
Download a third-party bibliography tool such as Zotero. The installer will add a plugin for LibreOffice.
I have used Zotero for large (100+ pages) documents, and many of my colleagues have used it for theses and dissertations.
Regarding the entry format, find a citation style that matches your requirements. There are thousands of different styles available. If none of them quite match, then create a custom style.
Login/Signup to Answer
2 followers
Asked: 2018-04-18 21:05:16 +0200
Seen: 39 times
Last updated: Apr 19 '18
