When I type "i" in Writer it switches to "I" - how to fix that?
When I type “i”(and) in writer it switches to “I”(AND) - how to fix that, 6.0.3.2 x64 PL
There’s more than one “path”/work-flow for this, but I think this one’s the simplest:
  • Go to Tools > Autocorrect > Autocorrect Options..., and ensure that the “Replacements and exceptions for language:” at the top of that window is set for “Polish”. (These settings operate on a per-language basis.)
  • Under the Replace tab (should be active), clear the “Replace” box and type in i.
  • That ought to take you to the line that defines “i” as upper-case “I”, with it highlighted. If it isn’t, click on it.
  • Click the Delete button.
  • Clicl OK.
Done. It is, of course, easily reversed.
To show the community your question has been answered, click the next to the correct answer, and (optionally!) “upvote” by clicking on the ^ arrow to express thanks. These are the mechanisms for communicating the quality of the Q&A in these systems. Thanks!
I have the same problem, but your solution doesn’t work for me. What are the other options you mentioned? I don’t know why, but in some Wirter files this problem appears, in others it doesn’t.
