Local help installation issue
Trying to install 6.0.4.2 on Linux Mint 18.3 with GB help file. (I prefer local help for when I’m not online - yes there are a few of us that live disconnected at times).
Don’t want to use Flatpak so please, no suggestions in this direction.
I’ve poked and prodded a bit but I’ve reached the point where I don’t know if I missed doing something or whether the installation dependencies are actually wrong. Any pointers gratefully received to get the help file installed properly.
Here’s what I did:
  • Uninstalled the distro version of LO and purged config files.
  • Downloaded 6.0.4.2 64 bit
  • Installed using dpkg
The applications work fine, but the local help shows as not installed within the applications.
However when I go to install the 6.0-en-gb help file I get
rick@tardismint ~/Downloads/LibreOffice_6.0.4.2_Linux_x86-64_deb_helppack_en-GB/DEBS $ sudo dpkg -i *.deb
(Reading database ... 550476 files and directories currently installed.)
Preparing to unpack libobasis6.0-en-gb-help_6.0.4.2-2_amd64.deb ...
Unpacking libobasis6.0-en-gb-help (6.0.4.2-2) over (6.0.4.2-2) ...
dpkg: dependency problems prevent configuration of libobasis6.0-en-gb-help:
libobasis6.0-en-gb-help depends on libobasis6.0-en-gb (>= 6.0.4.2); however:
Package libobasis6.0-en-gb is not installed.
libobasis6.0-en-gb-help depends on libobasis6.0-en-gb (<= 6.0.4.2-2); however:
dpkg: error processing package libobasis6.0-en-gb-help (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
If I try to fix using apt-get
The following packages will be REMOVED
0 to upgrade, 0 to newly install, 1 to remove and 26 not to upgrade.
1 not fully installed or removed.
After this operation, 25.7 MB disk space will be freed.
Do you want to continue? [Y/n]
…and while trying to remove some other stuff using autoremove showed:
DEBS $ sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run ‘apt-get -f install’ to correct these.
The following packages have unmet dependencies.
libobasis6.0-en-gb-help : Depends: libobasis6.0-en-gb (>= 6.0.4.2) but it is not installable
Depends: libobasis6.0-en-gb (<= 6.0.4.2-2) but it is not installable
E: Unmet dependencies. Try using -f.
Which squares with the content of the control file in the help .deb
You can’t install versions non supported by your OS without problems and most of the times you cannot install them at all because of missing dependencies. For how to install missing dependencies (if it is overall possible, without screwing the whole system) the right place depends on your repo.
