Splitting a page into three vertical parts
Hi there,
I’m trying to create a template for receipts with three copies - one for the person, one for the head office and one for the local office. So I need the same information on one page like this:
Top part for person
Name, Address, Phone
Amount, Date
Middle part for head office
Amount, Date
Bottom part for local office
Amount, Date
I’m printing on perforated 8.5x11 inch paper, so I’d like to easily split the page into three parts in LibreOffice Writer so I can just write the top part and then copy and paste it into the bottom two.
How can I do this?
Thanks!
Do you get the data from a data base? If the three parts are identical in content, then labels would work.
Or do you only looking for a way to avoid manually copy and paste from the first part to the second and third one? Then sections might work. Or is there a fixed text where only some values have to filled? Then a template with user fields might work. There are many ways. Please add some more information, then we can try to find a solution for your needs.
The three parts are identical, but I change them from time to time. I’m using Writer to create a fillable PDF form, so if I could create the top part (with text and form fields) and then copy the text and form fields to the next two sections, that’d be perfect.
I think sections might work, but I haven’t used them before, so I’ll have to read up on them.
