HELP sort a column based on data in another column
asked 2018-11-23 11:21:16 +0100
SHano gravatar image
updated 2018-11-23 12:57:15 +0100
image description
In the Above worksheet I have two columns, Column A Data has a matching row that contains the text in Column B eg. 2017_PS_DE_Epay_gCard_WEWCY_VD_BAR.eps from Column A and WEWCY from Column B
I am looking to re sort Column A into a new column so the rows match the corresponding Data in Column B
1 Answer
answered 2020-07-17 16:38:15 +0100
LeroyG gravatar image
Paste in C1: =VLOOKUP("*"&SUBSTITUTE(MID(B1;FIND(" ";B1);99);"x.x";"")&"*";A:A;1;0)
Drag C1 down into all occupied rows, then choose menu Data - Text to columns…, unmarck checkboxes, OK. Check results for possible errors.
Formula adapted from @m.a.riosv at ask.libreoffice.org/es/. An ad hoc answer is welcome, then I delete mine; I'll upvote.
Login/Signup to Answer
1 follower
Asked: 2018-11-23 11:21:16 +0100
Seen: 102 times
Last updated: Jul 17
