Need help correcting strange manuscript formatting problem
asked 2019-03-02 22:48:17 +0200
provlima gravatar image
updated 2019-03-02 22:55:44 +0200
Im having a problem with the formatting of a few pages of a 230 page manuscript that is best illustrated in the two images below
There are about 3 or 4 pages whose dimensions are significantly larger than others.
I have not been able to correct this formatting problem. Can someone please tell me how to correct this Thanks for your help!
image description
image description
There is a change in page style, but to understand what's causing it we need to look at the actual document. Please, upload it so we can see what's going on.
RGB-es gravatar imageRGB-es ( 2019-03-02 23:27:49 +0200 )edit
  1. Read this tutorial (and this one might be helpful too).
  2. If you can’t find an answer, read these guidelines and ask a good question.
gabix gravatar imagegabix ( 2019-03-03 12:01:06 +0200 )edit
Thank you for your response I would like send you the two different page styles for your analysis but am a loss as to how would I upload a single page from a 230 page manuscript?
provlima gravatar imageprovlima ( 2019-03-03 17:25:38 +0200 )edit
@provlima just save a copy of the file and cut the content before and after the anomalous point to let a few pages showing the problem, then edit your question and attach the resulting file.
RGB-es gravatar imageRGB-es ( 2019-03-03 17:28:58 +0200 )edit
