[solved] Draw: Paragraph Alignment does not work!
Hello, for some reasons, the horizontal text alignment doesn’t work in Libre Office Draw. If I do: INSERT, TEXT BOX, and I over size the box, then pick ALIGN RIGHT, the text remain to the left of the box. The vertical alignment however works. Any idea?
Check the properties of the text box (mouse right click) > Text… > Text Anchor
Probably there are contradicting adjustments?
Please add: OS, LO version (edit your question)
That’s it!!! The anchors… thx so much for your help.
