Need help printing to 5X8 paper
asked 2019-08-15 19:51:08 +0200
pj6 gravatar image
updated 2019-08-16 01:23:02 +0200
I need help printing to 5X8 paper. I have the page properties set to 5X8. I can save to pdf and print to 5X8 that way; however, the built-in pdf converter does not handle certain special characters properly. I would like to print from LibreOffice directly, but no matter what I do on the print dialog it prints as if to letter-sized.
The print dialog appears to be missing the controls to select the paper size.
Version: 6.2.5.2 Build ID: 1ec314fa52f458adc18c4f025c545a4e8b22c159 CPU threads: 4; OS: Mac OS X 10.14.2; UI render: default; VCL: osx; Locale: en-US (en_US.UTF-8); UI-Language: en-
LibreOffice: image description
Safari: image description
You can't select 5x8 in Paper Size: (middle of the second screenshot)?
Opaque gravatar imageOpaque ( 2019-08-15 23:13:49 +0200 )edit
The second screenshot is Safari. I put it in there for comparison. That option doesn't exist in the first screenshot.
pj6 gravatar imagepj6 ( 2019-08-16 01:25:03 +0200 )edit
1 Answer
answered 2019-08-16 12:30:00 +0200
from the print dialog select Paper Handling (instead of LibreOffice which is on your first screenshot) and tick "Scale to fit paper size" and you'll be able to select the "Destination Paper Size". See the following screenshot:
image description
If the answer is correct or helped you to fix your problem, please click the check mark (✔) next to the answer.
That has no effect.
pj6 gravatar imagepj6 ( 2019-08-18 00:03:11 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2019-08-15 19:51:08 +0200
Seen: 27 times
Last updated: Aug 16
