formatcell popup window spans multi-monitor
I am having this problem with calc that I can not reduce the size of the popup window for “Format Cells”. The “Format Page” popup does not do this. I can not resize, nor is the option to resize available in the menu for this window. I have uninstalled and reinstalled, deleted my LibreOffice application folder, and changed setting inside the config file (registrymodifications.xcu), but nothing helps. What else can I do?
Installed Version: 6.1.5.2 Build ID: 10(Build:2) on openSUSe 42.3 with dual monitors 1440x900.
What do you mean by deleted my LibreOffice application folder - you deleted $HOME/.config/libreoffice/4/user ?
This sounds like a Window rule is forcing this - Which desktop manager are you using (KDE, GNOME, any other)? (I could reproduce such behavior on openSUSE 15.1 KDE forcing a specific window size)
In the past if there were any problems with a user’s personal configuration of OpenOffice, ie: dictionary, personal settings, etc…, it was stated in other forums to delete the folder containing the settings, to allow OpenOffice/LibreOffice to regenerate the settings folders and files.
I am using Xfce. Also, only the “Format Cells” popup for scalc does this. No other pop ups do for any other LibreOffice application.
