Several of us on our team are using LO 6.3.4 on MacOS (Mojave). We’ve continued to encounter strange behavior when trying to edit existing text.
Every so often when I want to edit an an existing sentence, I’ll click where I want to edit to place the cursor, then I’ll hit space, and start typing to insert a word or two. The spaces do not insert correctly – they are added after the cursor, and the cursor stays in place. If I hit the space bar again, it adds another space after the cursor. Sometimes I can temporarily fix the problem by moving the cursor – clicking elsewhere or using the arrow keys to leave and come back. Sometimes that fixes the problem for a bit, sometimes it doesn’t. It makes typing frustrating, and editing an existing document a very slow task.
Has anyone else experienced something like this? Is there a way to fix this? It makes LO almost unusable for daily work.
