"Insert" Problems with Tables in Impress
Problem:
When using tables in Impress, new inserted columns seem to have bulletted text in them and do not adhere to table-wide font changes (being stuck in Source Code Pro 24). I should also note that there is a weird indent to them as well. To fix this, I have to manually set each box to not have a list in them in order to fix this. If any of this is unclear, I can record it. If this is a bug in LO specifically, I can report it too!
Simplified Steps:
  1. Create a new table of any size, note that the font for every cell can be changed through the Table Properties... menu and is in non-bulletted mode
  2. Right click, go to Insert, and insert cells after the current column
  3. You will see that each new cell is filled with bulletted text with a different font than the rest of the table. You will not be able to change this font unless you remove the bullet point.
Info:
OS: Manjaro Linux
LO Version: 6.4.0.3 40(Build:3) from libreoffice --version in a terminal
Bug Report Here: #130788
I can largely confirm that.
However, the font can also be changed for me without removing the dot beforehand.
image description
You can enter a bug in Bugzilla or see if there is already an entry for it.
Please announce the link from the bug here. To do this, edit your initial question.
Do not post an answer if it is not a solution to your question. Thank you.
With me Windows 10 Home; Version 1909; 64-Bit | LibreOffice, Version: 6.4.0.3 (x64).
