my Database HSQLDB 2.5 in window CPU but access with LMDE 4 “Debbie” linux with java 11 using libreoffice base
But when try to open window based Database HSQLDB. connection setting “connection established” but no table displayed. LMDE 4 libreoffice base.
i using (using database Url) hsqldb:\xxxxx/xxxx/\database/mydb;default_schema=true;get_column_name=false
is any linux needs some special type of URL setting missing in connection link
Thanks
