Problem with SUMIF - maybe using dates
I am trying to calculate a rolling average over a date series with irregular dates.
The formula I’m using is =SUMIF(A$4:A4,">"&F4,B:B) where the A column contains the dates in ascending order, the F column contains the date from the A column less the period for the average. But the results aren’t what I’d expect. The first row for column G in the screenshot should say ‘800’ but it doesn’t. It looks as if the column’s shifted down a few cells.
image description
Any idea why?
Your B:B effectively is B1:B1048576 so the date criteria matching from A4 on as first row starts to sum at row 1 of column B. You want to start to sum from row 4 as well, so
=SUMIF(A$4:A4;">"&F4;B$4:B$9999)
(or whatever max row number instead of 9999).
Thanks @erAck. I thought it would synchronise the two columns.
