work on 2 documents side by side
Am I able to work on 2 documents (either word, spreadsheet, draw or presentation) side by side on the same screen?
First time here? Check out the FAQ!
As others have mentioned, each file will be its own window. If you'd like to make the "side by side" activity easier:
In a common application window (like MDI): No.
On the same screen: Yes.
There they (the document views) are anyway, just mostly positioned overlapping (or even using the same area completely).
You need to arrange the container windows per document as you want them. This positioning and shaping is not specifically supported.
You would need some macro programming to automate the "side by side" presentation as you prefer it.
The StarDesktop variable predefined for LibreOffice Basic knows everything about the container windows you need.
The documents are presented in separate windows under LO. Adjust the window sizes to tile them side by side.
To show the community your question has been answered, click the ✓ next to the correct answer, and "upvote" by clicking on the ^ arrow of any helpful answers. These are the mechanisms for communicating the quality of the Q&A on this site. Thanks!
Asked: 2020-11-19 13:01:31 +0200
Seen: 85 times
Last updated: Nov 19 '20
Suppress Java errors when installing from an msi [closed]
How do I get document information from the command line? [closed]
What does the updater do? [closed]
Libre 3.5 Install/run fails - win7 home [closed]
are there any plans for a new Interface (GUI)? [closed]
Are there any usability tests regarding LibreOffice? [closed]
Fresh install of 3.5 on Win 7 64 fails to start. [closed]
