Sort with numbers and text in same column
I have a column with numbers an d text.
I would like to sort my CALC file on that column.
BUT ... after sort:
1
1
1
18
19
2
201
222
Finally aa ac tg rf ...
I would like to see 1 2 3 4 5 … 9 10 11 … 19 20 21 … 29 30 … aa ac tg rf
How can I accomplish that ?
Thankx,
⌡im
TNX,
⌡im
(Slightly edited by @Lupp for better readability)
Activate Enable natural sort in the Options tab.
More LibreOffice Help on Sort options.
Tested with LibreOffice 6.4.7.2 (x64); OS: Windows 10.0.
Add Answer is reserved for solutions. If you think the answer is not satisfactory, add a comment below, or click edit (below your question) to add more information. Thanks.
Check the mark (Answer markCorrect answer mark) to the left of the answer that solves your question.
If the answer helped you, you can mark the up arrow (Upvote mark) that is on the left (to vote, you need to have karma of at least 5).
'SORT OPTIONS" is a wonderful resource … Thanks.
'Natural Sort" was enables, but the sort was the same; 14, 15, 16, 17, 18, 19, 22, 33, 45 … aa, ac, dc, frt …
Any other ideas?
Jim
Originally:
BUT … after sort:
1
1
1
18
19
2
201
222
Now:
… the same; 14, 15, 16, 17, 18, 19, 22, 33, 45 … aa, ac, dc, frt …
So what is your actual data? I cannot see that problem that you described initially, where 2 followed 19, here in your last reply; and what you wrote looks perfect - each number goes after smaller number, non-numbers follow numbers. What is wrong here?
And also - what you wrote is not answering your question, so should not be an answer. Re-write it as a comment to the answer that didn’t work for you.
would prefer; 1, 2, 3, 4, …
Rather than; 1, 10, 100, … 2, 20, 200 … a, b, c, …
Natural sort does not solve the problem.
TNX, ⌡im
