Cyrillic characters issue
asked 2021-02-14 12:41:28 +0200
chibo gravatar image
updated 2021-02-14 13:20:13 +0200
ajlittoz gravatar image
Everything is ok, but it won't work!
Copy/paste from/to LibreOffice is always broke my cyrillic characters
ArchLinux Plasma bleeding edge..
(inline display fixed by ajlittoz)
Edit your question to better explain what we should look at. Your screenshot is a mess: there are many overlapping windows and the dark theme does not help to see the borders. It is also difficult to tell which window is related to which application.
Apparently, the light gray window is LibreOffice but the status bar is missing (to have notification of the current language) and the menu bar too.
Have you clipped many screenshots and glued together the bits into this picture? As is, we can extract no useful information from it.
What have typed? How should it be displayed? Where do you copy from (which application)? Where do you paste into? What is the format of copied data? How do you want it to be pasted (plain text, formatted text, …)? Have you installed a non-standard clipboard manager?
Please do not use Add Answer but edit your original question ...(more)
ajlittoz gravatar imageajlittoz ( 2021-02-14 14:04:12 +0200 )edit
And what is the locale?
gabix gravatar imagegabix ( 2021-02-14 15:06:05 +0200 )edit
just look at the screenshot
chibo gravatar imagechibo ( 2021-02-15 16:20:34 +0200 )edit
Yep, but to see what?
ajlittoz gravatar imageajlittoz ( 2021-02-15 16:34:16 +0200 )edit
chibo gravatar imagechibo ( 2021-02-16 10:29:08 +0200 )edit
If you really expect help, give us more details. Into which applications do you copy/paste text from/to Writer?
You seem to show a text editor window. Is this text editor configured for some ISO-8859-x variant?
Eventually, edit your question to attach the Writer file with "Dasdasd + ifvafivfivfivf" and the text editor file .
ajlittoz gravatar imageajlittoz ( 2021-02-16 11:55:50 +0200 )edit
