Calc TableBorder problem
Has anyone gotten TableBorder to work putting a border around a range of cells?
From what I read this should work but I don’t see a border when run.
aRange = ThisComponent.CurrentController.ActiveSheet.getCellRangeByName("B2:C3")
setRangeBorder(aRange)
Sub setRangeBorder(oRange)	'	doesn't seem to be working for me, don't see why
	Dim oBorder, oTBorder
	oBorder = CreateUnoStruct("com.sun.star.table.BorderLine")
	oBorder.Color 					= RGB(150, 150, 150)
  	oBorder.OuterLineWidth 			= 35
  	oBorder.InnerLineWidth 			= 35
	oBorder.LineDistance 	 		= 3
	oTBorder = CreateUnoStruct("com.sun.star.table.TableBorder")
	oTBorder.IsLeftLineValid 		= True
	oTBorder.IsTopLineValid 		= True
	oTBorder.IsRightLineValid 		= True
	oTBorder.IsBottomLineValid 		= True
	oTBorder.LeftLine	 			= oBorder
	oTBorder.TopLine 				= oBorder
	oTBorder.RightLine	 			= oBorder
	oTBorder.BottomLine 			= oBorder
	oRange.TableBorder = oTBorder
I’m hoping someone will show me the error of my ways or point me towards a working example.
To further complicate matters, Pitonyak’s OOME Listing 411 when I run it doesn’t give me the blue boxes only 2 red lines. Can there be something I’ve set to prevent it from running for me as it did for him?
Thanks,
Mike
This is a solution lacking an explanation.
LO Version: 6.1.5.2
In the above BorderLine definition, if InnerLineWidth and LineDistance are set to 0 or
removed the border box is drawn.
If only the Color and either LineWidth is present the box is drawn.
I'm unable using BorderLine and TableBorder to draw a double line border.
Using BorderLine2 Pitonyak in OOME P467 draws a double line border,
another sample is here: https://wiki.documentfoundation.org/Macros/Writer/003
A pretty good discussion can be found here:
  https://forum.openoffice.org/en/forum/viewtopic.php?f=9&t=59293
Initially I started out just to put a border on a single cell as in
With oCell
  .TopLine = oBorder
  .LeftLine = oBorder, etc. but it didn't seem to be working.
Defining oBorder with only a Color and one LineWidth,
be it either Inner or Outer fixed the problem.
One note worth mentioning if you plan to use this, a range can consist of a single cell
so only one sub is needed if you define it using BorderLine and TableBorder.
Should anyone find a way or example to make the double line border using LO's
BorderLine and TableBorder, please post it here.
Likewise if you find a reason why it does not work as expected, I'd like to see that here.
Thanks,
Mike
