Base faults without JRE why is it not included with downloads? [closed]
Base must have JFE?
First time here? Check out the FAQ!
Base must have JFE?
https://www.libreoffice.org/get-help/faq/general-faq/does-libreoffice-require-java/
(That page is gone, try this Archive.org link instead: [http://web.archive.org/web/20121028235704/http://www.libreoffice.org/get-help/faq/general-faq/does-libreoffice-require-java/] )
The embedded databse engine (HSQLDB) requires java, but if you're just using Base to connect to an external database such as MySQL or PostgreSQL, no java is required.
I believe that java is not included in the default download:
This question looks related:
http://ask.libreoffice.org/en/question/2968/base-says-my-java-runtime-environment-is-defective/
Side Note: There was a push to remove the java dependency in Base by changing the default built-in database from HSQLDB -> SQLite. Due to technical limitations in SQLite, this change was abandoned.
Asked: 2012-12-22 09:05:08 +0100
Seen: 753 times
Last updated: Feb 03 '13
What features absolutely require Java ? [closed]
Increasing Java heap space for Base on Mac 10.6 [closed]
Suppress Java errors when installing from an msi [closed]
arabic language support [closed]
Any way to speed up database search? [closed]
Installation on Fedora 14 system fails. [closed]
converting perfect works data files [closed]
