How to sum only cells with negative values in a column?
Hi everyone!
How do i select and sum only the cells with negative values in a column?
My first question and I am totally new to spreadsheet (of what ever brand but I choosed Libre).
My question.
In the picture above, I want the total sum of cells with negative values in column “C” (that is C18 and C28 “-8800 and -9800 which is -18600”) to be inserted in cell “I12”.
How do I achieve this?
Thanks in anticipation.
Meanwhile I got the spreadsheet (about 8 sheets so far) done this far by getting answers here; please don’t fail me on this one as I could not find answer to this particular challenge.
**[Edit - Opaque]** Shortened title and moved the text to details.
Always better to upload a real ODF type sample file instead of a static picture. A real document file
  1. smaller than a picture file (usually).
  2. it gives us more informations about your problem.
Read these guidelines and ask a good question. In particular, make the title short.
Thanks for your response.
Please how do I do that?
Click the Edit link at the end of the title?
i think you are looking for the SUMIF function
image description
Take a look here
https://help.libreoffice.org/6.1/en-US/text/scalc/01/04060106.html?&DbPAR=CALC&System=UNIX#Section15
Hope that helps.
Have a nice day and let’s (continue to) “Be excellent to each other!”
Thanks a million. It worked.
Why can’t I up vote your answer?
You need a bit of karma to upvote, i upvoted your question, so you should be able to vote on answers now.
Upvote works now, How did you add the picture and how can I mark this as solved?
Thanks for the vote.
In questions and answers there should be a edit button to upload images, Not sure if there is also a karma requirement for it to be usable/present. You can hover over your karma (right of you username and see what you are allowed/capable of doing)
Have a nice day.
use: SUMIF(C6:C28;"<0";C6:C28)
Hope that helps.
You nailed it… I would have shown you a screenshot but I can’t find a way to add picture to comment. Thanks a million.
Why can’t I up vote you answer?
