Problem with a graph
Hello, I have created the following graph and would like to have the years at the bottom of the graph. Would you tell me how to do it? I just can’t find it. Thanks in advance
image description
For better layout Y axis was scaled: Minimum (manually) → -20
Vielen Dank. Du hast mir viel Zeit gespart.
For better visualisation I would combine @anon73440385 and my solution:
  • insert second X axis and let it cross Y axis at 0. Edit second X axis (thickness, colour).
  • Select your X-Axis
  • Right click -> Format Axis -> Tab: Positioning -> Option: Place labels -> Dropdown: Outside start
Dialog
Result
image description
Hope that helps.
