is there a way to read keywords in document properties.
Looking for a way to read (search) keywords in a write document. Would like to be able to list all docs in a directory containing the keyword.
Is this possible?
Thank you for your time.
~Respect
Have you looked at Question 61310? OOo forum Search content of odt file might throw some light.
Personally, I turned off indexing as it was unhelpful and slowed everything down. Cheers, Al
Not an LibreOffice question, but…
In Windos 7 (6.1) you can show the tags(?)¹ column in the File Explorer.
¹ Etiquetas. I an on Windows 7 in Spanish, sorry.
Tested with LibreOffice 6.4.7.2 (x86); OS: Windows 6.1.
Add Answer is reserved for solutions. Please, click edit below your question if you want to add more information, or add a comment below.
