Split screen in Write
How do I show 2 pages of text, side by side, in a vertical split screen format?
Please edit the question to indicate if the reference is to:
  • Two adjacent pages from the same document.
  • Two non-adjacent pages from the same document.
  • One page each from a different document.
FWIW, I’ve found I can achieve roughly the same by using the Windows Aero Snap features.
Bug 31481 - [RFE] Split pane in same window for side-by-side proof reading/ translating of 2 different files
In short, you can’t. Of course, if you just need to see two consecutive pages side by side, use the zoom controls to the right of the status bar at the lower part of Writer’s window.
