[solved] Insert value from cell into formula
I’m puzzling with the following question.
I’m pointing to the cell Setup.$C3. However, the 3 should be a value from another cell (in row E (same sheet, not setup), like 3,4,5,6 et cetera). Just tried several options like:
setup.c&(E3)
setup.c&"E3"
et cetera.
How can i use a value from row E into a formule and combine it?
You’ll want to use the INDIRECT function that converts a string to a formula, that is:
=INDIRECT("Setup.$C"&E3)
Thanks! Never heard of INDIRECT until now.
This works fine.
But if you change the sheet name or insert/delete a column in A or B or both, the formula is not adjusted.
There are other options to do the job (see details and samples in the LibreOffice help):
INDEX returns a sub range, specified by row and column number, or an optional range index. Depending on context, INDEX returns a reference or content.
Syntax
INDEX(Reference; Row; Column; Range)
OFFSET returns the value of a cell offset by a certain number of rows and columns from a given reference point.
Syntax
OFFSET(Reference; Rows; Columns; Height; Width)
