Hi fellow,
I want to adjust space between the bottom edge of the writable area and the footer, so I edit Spacing from Footer properties but this works for footers except the first page footer.
How can I fix it?
Hi fellow,
How can I fix it?
When you have different page styles, you have to set the spacing for footers in each page style.
If this answer helped you, please vote it with (here on the left). That will help other people with the same question.
I have the same style.
anyway, the problem is simply a bug!
just close and reopen LO in order to update the view…
I’ve reported it here: https://bugs.documentfoundation.org/show_bug.cgi?id=102097
solved with 5.2.2 version
