How do I set u APA running headline on your worksheet. I have it downloaded but doesn’t say same things as windows office sheet. I am new to online college and they want APA running head
When they ask for a “running head”, they are using publisher terminology for what most word processing software refer to as a “header” or “page header.” [Thank you @oweng.]
You can read the LibreOffice User Guides, in particular LibreOffice Writer Guide, Chapter 4 “Formatting Pages” and LibreOffice Calc Guide, Chapter 4 “Using Styles and Templates”, the sections corresponding to setting up headers and footers.
As for the APA head format, I do not know anything about it, but I found this link: Running Head Format for APA Style Papers.
“Running head” is publisher terminology for what most word processing software refers to as a “header” or “page header.”
@carnendil, that was not a criticism on your answer (which is correct, and which I marked up), but rather just a bit more information for others. I should have been clearer
@oweng, I have added your comment in my answer. Thank you again. It might have been the source of confusion to the OP or might confuse others in the future.
It’s super easy actually,
Add your headers as you normally would
go to Format > Page > Header
and you should see a check-box that says Same content on first page
UN-check that box and you will be able to edit your first page without the other ones changing!
