Today, eventually, I managed to solve a critical problem with Mysql Direct Connector (see this post), but even though now I can see tables and queries in my odb, I still get an error message when I open a form with a subform.
This is the error message:
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ':link_from_ID_classe ) ORDER BY "ID_classe", "cognome", "cognome" ASC' at line 1
And the syntax is this
The SQL command leading to this error is:
SELECT "studenti"."ID" AS "ID", "studenti"."cognome" AS "cognome", "studenti"."nome" AS "nome",
"studenti"."data_nascita" AS "data nascita", "studenti"."abitazione" AS "abitazione", "studenti"."via" AS "via",
"studenti"."telefono" AS "telefono", "studenti"."origine" AS "origine", "studenti"."ID_classe" AS "ID_classe",
"studenti"."dati_personali" AS "dati personali", "studenti"."situazione_scolastica" AS "situazione scolastica",
"studenti"."voto_matu" AS "voto matu", "studenti"."significativita" AS "significativita" FROM "miei"."studenti" "studenti"
WHERE ( "studenti"."ID_classe" = :link_from_ID_classe ) ORDER BY "ID_classe", "cognome", "cognome" ASC
Therefore now I see, in my form, the main form (correctly), but the subform is empty.
What should I do?
