Base; Split DB AutoValue fix not working [closed]
asked 2017-08-27 16:37:11 +0200
Joe Castor gravatar image
I completed the conversion to a split DB, following the instructions for fixing the AutoValue in appropriate tables. After several attempts, and reviewing the procedure document several times, I can't get it to work. When changing it from Yes to No, then back to Yes, it appears as shown on the instructions, but after saving the new table then opening it in edit, it shows as AutoValue No, which then can't be changed. Any suggestions of what I might be doing wrong? Thanks in advance, Joe
Closed for the following reason not a real question by Joe Castor
close date 2017-10-11 02:31:56.417294
1 Answer
answered 2017-08-27 17:06:50 +0200
Okay, it seems to be working. After doing the yes to no to yes step, I selected a different field, then back to the autovalue field, then saving it, the autovalue yes remained. Sorry for the false alarm.
1 follower
Asked: 2017-08-27 16:37:11 +0200
Seen: 125 times
Last updated: Aug 27 '17
