database connection problem in windiw 10
asked 2017-08-31 19:14:59 +0200
koolninja gravatar image
updated 2017-08-31 19:20:59 +0200
Before I am using window 7 with liberoffice 5.3. Front hand liberoffice base and backhand HSQLDB. All working fine in window 7 but migrates to window 10 with liberoffice 64 bit and Java for 64bit. Showing java not loaded and not get connected to database. Any suggestion regarding this
1 Answer
1
answered 2017-08-31 22:54:54 +0200
m.a.riosv gravatar image
Have you installed a LibreOffice x64?, LibreOffice and Java must be equal, x64 or x86.
Yes I have installed liberoffice x64 and Java x64
koolninja gravatar imagekoolninja ( 2017-09-01 05:05:03 +0200 )edit
And is the right Jave selected on Menu/Tools/Options/LibreOffice/Advanced.
m.a.riosv gravatar imagem.a.riosv ( 2017-09-01 15:39:19 +0200 )edit
Thanks your suggestion is right
koolninja gravatar imagekoolninja ( 2017-09-02 17:29:02 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2017-08-31 19:14:59 +0200
Seen: 52 times
Last updated: Aug 31 '17
