Problem scaling symbol in Math
I’m using windows 8. I have a problem with symbol scaling in Math, a simple formula as "y=sqrt{ x} < x <= x^2 " is draw in erroneous way, the symbols are little respect the rest of formula. The symbol sqrt is draw with a break between √ and overbar, √ and ≤ are smaller than necessary.
What could be the problem?
Hi @AndreaA,
I just pasted your formula into LO 4.0 (on Ubuntu 12.04.2), and I agree: That square root sign looks pretty bad at certain zoom levels. Maybe I’m just spoiled by LaTeX, but I’m hopeful that we can improve the rendering.
Please file an enhancement bug and provide the same information you provided above. Don’t forget to mark your bug as an ‘enhancement’. The QA team will be happy to help you triage your feature request in the bugtracker.
Please post a link to any bugs you file in a comment below using the format “fdo#123456”.
Thanks!
Hi, i post a bug “fdo#61622” with a attachments (png) where you can see how the formula is draw. Thanks.
fdo#61622 has been marked as a duplicate of
Bug 60268 - FORMATTING: Square root and cdot are not correct displayed under Windows 8
Status: NEW
See also: fdo#69851
Go here :
link text
or
link text
