impress will not import mp4
asked 2017-10-13 06:08:37 +0200
ccurley gravatar image
updated 2017-10-13 06:12:07 +0200
Version: 5.2.7.2 Build ID: 1:5.2.7-1~bpo8+1 CPU Threads: 4; OS Version: Linux 4.9; UI Render: default; VCL: gtk2; Locale: en-US (en_US.utf8); Calc: group
I have a presentation I created several years ago, with two embedded MP4 files. It used to work. Impress now will not play the mp4s.
I started a new presentation, and tried to import them into the new one. Impress reports it does not support the file format. Same with the media player (Tools -> Media Player).
Both files play in VLC.
$ file *.mp4
cpp.navaho.tppf.mp4: ISO Media, MP4 v2 [ISO 14496-14]
we.were.warned.mp4:  ISO Media, MP4 v2 [ISO 14496-14]
Does old presentation play with LibreOffice 5.2.7 (no importing to new presentation). I would try LibreOffice 5.3.6. Videos in Impress never quite worked for me on Debian (but didn't used them much). My be helpful: impress playing mp4
You probably don't have appropriate codec installed on operating system level. VLC has it's own set of codecs and that's why your files play in VLC and not in Impress.
Kruno gravatar imageKruno ( 2017-10-13 10:02:50 +0200 )edit
You should also change title as seams that you can import files, but they don't play.
Kruno gravatar imageKruno ( 2017-10-13 10:06:20 +0200 )edit
How do I tell which codec(s) I need, then? I understand that LO uses gstreamer. I have the following Debian packages installed:
gstreamer0.10-plugins-bad 0.10.23-7.4+deb8u2
gstreamer0.10-plugins-base 0.10.36-2
gstreamer0.10-plugins-good 0.10.31-3+nmu4+deb8u2
gstreamer0.10-plugins-ugly 0.10.19-2.1
Previous versions of LO have imported and played these MP4s successfully.
I can also play these with xine.
ccurley gravatar imageccurley ( 2017-10-25 05:38:25 +0200 )edit
I don't know what might be wrong as I don't use this feature very often. Can you try with 5.4?
Kruno gravatar imageKruno ( 2017-10-25 12:56:07 +0200 )edit
