Right Border Problem? [closed]
Hello All,
At the moment I am using LibreOffice to try and print out certificates for our Martial Arts dojo. To that end I went and found some templates that worked with LibreOffice. The templates looked good on-screen though I need to make some modifications, however, when I went through a trial print through to make sure everything would come out correctly, the right side of the page cutout and didn't show the border of the graphic, and I cannot figure out how to correct this.
Using a ruler I found out that on the right side the printing is stopping 33mm from the edge of the document.
Any help on how to correct this would be "greatly" appreciated!
Thankyou and Regards.
