Greetings,
I’ve installed the Help a few times but LO doesn’t recognize it when I try to use it (either by pressing F1 or clicking the Help option within the Help menu). What would be the problem?
Using Version: 5.4.2.2
Thanks,
Starkman
    Greetings,
Thanks,
Starkman
Be sure you are using the same language on the help and in Menu/Tools/Options/Language settins/Language/Language of User Interface.
Yeah, it’s all set to the same language.
I installed the newest version (5.4.3.2) and that fixed the issue. Weird, but hey, it works!
