How to fix LO5.4.3.2 not opening a file on right click under macos Sierra
asked 2018-02-04 04:25:07 +0200
In the past, right clicking on a LO file would allow the app to open the file immediately. While you can select that option, the end result is that the application launches and shows the 'Recent Files' menu from which you must choose the file, but why the unnecessary step? If I right click on an LO file and select Open with LO, it should just do it and get out of the way. Thanks.
