What steps would I take to create a cross-reference to a heading?
HEADING
see HEADING for more details
Insert>Cross-reference. Alternatively, open the “Fields” dialog (Insert>Field>More Fieldsor Ctrl+F2) and click theCross-referencestab. - Select “Headings” under
Typeand “Reference” underInsert reference to. - A list of headings should appear. Select one and click the
Insertbutton.
Edit: Improved as per @jimk’s comment. Revisions for clarity.
Insert → Cross-reference requires fewer steps.
OK, it does enter the title of the heading if ‘Reference’ is selected. Items in the table of contents are link-able (clicking while holding down the left Ctrl key). The cross reference is not link-able. Is it possible to make it link-able?
When I click on the cross-reference of a heading, it jumps to the heading. Tested with LO 5.4.3.2 starting with a blank document.
Ah, I’ve gotten so used to having to open the Fields dialog that I completely overlooked the shortcut. Thanks @jimk.
