on spreadsheet I have 4 way arrow locked on to 1st collumn. how do I undo?
Maybe a 4-way Arrow shape.
Click on it, choose menu Format - Object - Position and Size…, uncheck Position (below Protect), and OK. Now you can move it (or press Delete).
Tested with LibreOffice 6.4.7.2 (x86); OS: Windows 6.1.
Add Answer is reserved for solutions. If you think the answer is not satisfactory, add a comment below, or click edit (below your question) to add more information. Thanks.
Check the mark (
) to the left of the answer that solves your question.
If the answer helped you, you can mark the up arrow (
) that is on the left (to vote, you need to have karma of at least 5).
