Problem with StarDesktop.loadComponentFromURL [closed]
asked 2018-10-10 20:03:37 +0100
dbondo gravatar image
updated 2020-08-06 13:31:13 +0100
Alex Kemp gravatar image
Ever since Star Office 9 I have been using Macros that have this code or identical ones with the Symbols changed:
Sub OpenDJIA_History
    rem define variables
    Dim Doc As Object
    Dim File As String
    Dim URL As String
    rem get access to the document
    File = "C:\Users\Doug & Dolores\Dropbox\Fund Data\39Wk Avgs\DJIA History"
    URL = ConvertToURL( File + ".ods" )
    Doc = StarDesktop.loadComponentFromURL(URL, "_default", 0, Array() )
Now all of the sudden when stepping through or running this Macro sub routine I get the following Error Message:
BASIC runtime error.
An exception occurred
Type: com.sun.star.lang.IllegalArgumentExceptionMessage: Unsupported URL
<file:///C:/Users/Doug%20&%20Dolores/Dropbox/Fund%20Data/39Wk%20Avgs/DJIA%20History.ods>: "type detection failed".
Any idea what has happend or how to correct the "loadComponentFromURL" code?
close date 2020-08-06 13:31:28.722283
What about copy "DJIA History.ods" from DropBox to local hard disk? For example to folder C:\Tests.
JohnSUN gravatar imageJohnSUN ( 2018-10-10 20:47:52 +0100 )edit
That's the way it was years ago at first, but since almost 7-8 years ago I have been using DropBox and it worked perfectly until yesterday when I was trying to copy this sub to a new Macro.
dbondo gravatar imagedbondo ( 2018-10-10 20:53:25 +0100 )edit
FYI - I tried your suggestion with a C:\Test\DJA_History. It worked. Here is the code:
sub OpenDJA_History rem define variables
Dim Doc As Object
Dim File As String
Dim URL As String
File = "C:\Test\DJA History"
So my guess is that something has changed in LibreOffice that doesn't like the path to DropBox.
dbondo gravatar imagedbondo ( 2018-10-10 21:26:12 +0100 )edit
Does it work with an & in the filename in Test directory?
Btw: to properly format the code, it should be all indented by additional 4 spaces.
Mike Kaganski gravatar imageMike Kaganski ( 2018-10-10 22:06:51 +0100 )edit
Also: the error is returned from LoadEnv::impl_detectTypeAndFilter() when there's no valid content found; could that be that the file itself is corrupt?
Mike Kaganski gravatar imageMike Kaganski ( 2018-10-10 22:18:22 +0100 )edit
