default zoom level for newly created spreadsheet stuck at 393%, how to reset it?
asked 2018-11-02 02:44:38 +0100
perlancar gravatar image
answered 2018-11-02 04:05:23 +0100
robleyd gravatar image
Open an existing file which will probably also open at 393%; reset it to the zoom level you want. Then try opening a new spreadsheet.
If this answer helped you, please accept it by clicking the check mark ✔ to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
nope, doesn't help. after opening other files and changing their zoom levels, creating a new spreadsheet still sets zoom level at 393%. even after closing all documents or restarting libreoffice, opening a new spreadsheet still sets zoom level at 393%.
perlancar gravatar imageperlancar ( 2018-11-02 04:22:15 +0100 )edit
answered 2018-11-02 04:23:32 +0100
Ok, I think I need to go to View > Zoom and change the level from there. it seems to stick.
Login/Signup to Answer
1 follower
Asked: 2018-11-02 02:44:38 +0100
Seen: 28 times
Last updated: Nov 02 '18
