How to fix missing java problem in base
asked 2019-03-13 04:44:11 +0200
dougmn gravatar image
I just opened a database file that I had not opened for a few weeks, and got this message:
"The LibreOffice configuration has been changed. Under Tools - Options - LibreOffice - Advanced, select the Java runtime environment you want to have used by LibreOffice."
The path that's offered when I go to "Tools - Options - LibreOffice - Advanced" doesn't contain a Java runtime environment.
When I try to open any of the forms or reports, I get this message: The connection to the data source “DatabaseName” could not be established. No Java installation could be found. Please check your installation.
Writer is working okay. I use it all the time.
Here's my the info on my installation:
Version: 6.2.1.2
Build ID: libreoffice-6.2.1.2-snap1
CPU threads: 4; OS: Linux 4.15; UI render: default; VCL: gtk3;
Locale: en-US (en_US.UTF-8); UI-Language: en-US
How do I fix this? Where can I find the lost JRE?
ebot gravatar imageebot ( 2019-03-13 06:44:11 +0200 )edit
1 Answer
answered 2019-03-13 06:00:02 +0200
Ratslinger gravatar image
Have never used snap versions so I don't understand why the configuration was reset.
First be certain on Advanced section at the top, Use a Java runtime environment is checked. If when checked nothing then appears in the window below it, proceed with finding Java install.
Java can be installed in a variety of different places in Linux systems depending upon the distro (you don't mention) the Java you have installed (Oracle, Open JDK) or if you just downloaded a version and extracted it to a directory of your choice (have done this a lot on Ubuntu systems). So the key is finding where yours is.
Based upon this post -> Where can I find the Java SDK in Linux? the method which best worked on my Mint 18.3 install was (using terminal):
cd /
sudo find . -name 'javac'
Once you find it you can add it under Advanced by pointing to the correct folder using the Add button on top right.
Okay fixed, by playing around a little bit. I had read this above from @Ratslinger more carefully, it would have been faster:
"Use a Java runtime environment" was checked, but something DID appear in the window below. It listed a JRE from Oracle Corporation, but the little circle was unchecked. Clicking that little dot, then clicking "apply" at the bottom got it fixed.
I don't know how it got changed in the first place, but I'm glad it's fixed.
dougmn gravatar imagedougmn ( 2019-03-13 21:57:10 +0200 )edit
I'm very grateful for this question and answer. Clicked the little dot, and now working.
henryg88 gravatar imagehenryg88 ( 2019-05-08 11:37:50 +0200 )edit
This did not work for me. When I tried
I got
./snap/core/7272/usr/share/bash-completion/completions/javac
./snap/core/7170/usr/share/bash-completion/completions/javac
./usr/share/bash-completion/completions/javac
find: ‘./run/user/1000/gvfs’: Permission denied
...not sure why I got Permission denied using sudo? Anyway, libreoffice base does not accept either of these three paths.
The folder you selected does not contain a Java runtime environment. Please select a different folder.
What can I do?
jvglynnjr gravatar imagejvglynnjr ( 2019-08-08 17:52:48 +0200 )edit
Login/Signup to Answer
1 follower
Asked: 2019-03-13 04:44:11 +0200
Seen: 2,590 times
Last updated: Mar 13 '19
